Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
Is it difficult to change the charging port?
So i have to hold the cable in a specific angle for the laptop to load. Should mean, that the charging port needs an exchange. Not i dont have any special equipment apart from screwdrivers. Is it difficult to exchange that part?
First you should try using a different charger. If that doesn’t work then you should go ahead and change the charging port. Its shouldn’t be a hard job it just takes patients and time.
do you think the charger may cause the problem? If it were the issue, then shouldnt it either be working or not working, regardless of wether i have to permanently keep it pushed to the top side of the charge port
No it can be a loos wire in the charger. But there is still a chance that it's the charging port. I recommend you first buy a charger with returns just in case.
dj-paok crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 196
