A singing, dancing, pink pony that responds to its included toys and outside stimulus.
Head/neck very loose and clicking
When I turn it on some of the moves it tries to do it clicks. Not positive what’s wrong but when it’s turned off the head and neck move around so I believe it’s either spring or motor there. I see the information for replacing motors or springs in legs but I believe it’s the head/neck. And where do I get the parts from to replace them??
Upon dissembling the toy, I found one of the reasons why the neck clicks. there is a small plastic tab on the tip of the black neck coupler.
this slides into the potentiometer located in the white base of the neck
. This controls the rotation of the neck and prevents it from clicking. It got broken off. I got lucky and found the broken tab when I took apart the toy and managed to glue it back it on. I don’t know if the glue will hold. If it does not I will try and scan the base and see if I can 3d print it. I will make the .STL file available if need be.
Hello, my grandma recently got my baby sister one of these from a thrift store and I'm trying to fix her up. This ponies neck is real loose, did that glue ever hold for you? Were you able to get that STL file up? Thank you in advance!
Jessica Hummell crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 662
