Apple Watch 4 tear down!
Hi! Is it possible to put it back together after complete tear down? Does back assembly need any seals to make it waterproof ?
thanks
thanks
Hi,
There is a gasket that resides around the screen, if done correctly, you shouldn’t have any problems, however this has not been tested and should avoid getting moisture in the device out of risk of damaging it.
I recently replaced the LCD on my apple series 44mm watch And it went into a boot loop on the apple symbol and when it finally kicked out of the boot loop I no longer have any touch capability so I’ve made a red the touch gasket unless I’m wrong if anyone has any suggestions I’m open ears. And it went into a boot loop on the apple symbol and when it finally kicked out of the boot loop I no longer have any touch capability so I’ve made a ripped the touch gasket unless I’m wrong if anyone has any suggestions I’m open ears It displays fine now just no touch
crwdns2942667:0crwdne2942667:0 789
