Introduced in 2016, the Brother MFC-L6700DW monochrome laser All-in-One addresses the business needs of workgroups with higher print volumes. It boosts printing and copying at up to 48ppm. The large 520-sheet capacity paper tray holds more than a ream a paper for fewer refills, and for additional capacity add-on trays boost total capacity to 1,610 sheets.
no power up when turn on
Not operational when turned on. Completely off
  1. Trace the power from source.
  2. Check the operation of the power switch (once in our office a printer’s power switch was found to be infested with ants).
  3. After that check the low voltage power supply board, if you can work out how to remove the covers.
Roman Misandzhi crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 492
