Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
Replacement display assembly not working after assembly
So i bought a display assembly for a Huawei P9 and for some reason it doesnt work after i moved all parts (cameras, mainboard, etc.)from one assembly to the other.
The weird thing is that it works totally fine when plug in the display flex cable before i assemble anything.
Any ideas?
You probably bet a ribbon cable, so look out not to bend them.
I don’t have a lot of familiarity with this model but check to make sure you aren’t putting pressure on any of the connectors or cables. Pinched cables can cause problems sometimes. Also, there might be something pressing on the screen causing it not to work. A bent frame can sometimes be the problem.
Antonio Cappuzzo crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 188
