serial # MVWX655DW I have no power
Have Bravos front loader serial # MVWX655DW I have no power
Start with your main breaker panel and reset the breaker to the washer. Next use a multimeter to check the wall outlet to see if it is providing power. Next use your multimeter to check the Line Fuse.
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
crwdns2942667:0crwdne2942667:0 805
