Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
recently replaced digitizer issuse
So, i recently replaced a digitizer not from ifixit.
and it worked for a few seconds but stopped working completley after a few good seconds home button was not working too. i opened up the mini again and inspected it. No issuses whatsoever and put it back on. digitizer and home button is not working at all. should i sell it for parts?
Did you have the same issue before replacing the digitizer? I suspect that replacement digitizer is defective, try another known working digitizer to confirm.
If issue persists, then you need someone with micro-soldering experience to fix as this is board related.
One thing I want to point out that the Mini/Mini 2 replacement digitizers are notorious for ghost touching (iPad activates itself erratically), make sure you cover the bottom strip near home button with Kapton or any ESD tape.
the old digitizer has the ribbon cable ripped out making it useless
Sins you didn’t buy it from ifixit i am assuming the quality was bad and thats why this happend. Do you still have the old screnn if you do try to see if it turns on. Is it recognized by iTunes?
the old screen is done beacuse i got it the ipad for free and the ribbon cable is gone for the old digitizer
it is recognised my itunes
Okay so just buy a new one from here and it should work
Zander Castillon crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 74
