Repair guides and support for a wide range of small engines.
Why wont my starter rope pull?
Hi, so I started a DIY mini ATV project with a 49cc pocket bike engine about a year ago. I started it once, then it sat in my garage for a while. The other day, I tried to start it again. When I tried to start it, the pull rope came out a bit then got stuck. I tried to pull harder, but it wouldn’t move. I took the pull start assembly off, and it pulled fine. The starter flywheel turned when I used a tool to push it. But as soon as I put the pull start assembly back on, it wouldn’t pull. Does anyone know what is wrong and how I could fix it?
Thanks in advance!
P.S I am only 13, so if the fix is obvious don’t judge. I don’t know much about this stuff.
crwdns2944067:07crwdne2944067:0
My ole man is having the same thing Happen to him He pulls and pulls and pulls Messing with the flywheel a little then it let's him pull a tiny bit then somewhat and freezes again please please someone help how can we get it to start… . Anyone b
I had a new CT-200 Coleman shipped to my home. Assembled, said it didn’t come with oil but, it did have oil in it. Topped off oil, added fuel, turned on gas, choked it & its locked up!
I have a coleman ct200u I never had something such a nightmare starting. If your lucky you might get a good pull right away if not I have to pull easy 2 times because its locked 3rd time I usually get a pull. Then if your lucky and it starts prey it didn't foul the plug again. I have a 212cc gokart its so smooth starting 1st pull
So my Coleman is now junk
i had the same exzact issue
crwdns2934275:02crwdne2934275:0
Greetings,
There are a number of things that can cause a starter rope to get stuck. If the engine has sat for a good bit the first thing I would do if it’s difficult to pull is remove the spark plug and ease the compression until I was able to get oil to start lubricating the cylinder again.
This could be a case of the cylinder isn’t lubricated due to sitting for a long time.
Monte
crwdns2944067:08crwdne2944067:0:
By lubricating, if you mean when I take the spark plug off to pour a tiny bit of oil/gas into the cylinder, I have tried that. Do you think it might just need to be lubricated more?
Yes, that is what i meant. the spark plug out means little to no compression. So if it still wont move and you have let some penetrating oil and etc. sit on it for sometimes days.
and you are sure that the mechanism for the pull starter is functioning correctly i would see if when it is removed if I could twist the main shaft and get it moving using some leverage and a wrench.
At that point, if I could not get the main shaft or piston to move with the spark plug out. I would suggest that you are likely going to have to pull it all apart and inspect each part directly.
I just received my 50cc , pulled just fine started and drove a little tried to pull the string again and it's hard to pull can u tell me what to do
I have the same problem I got a new Coleman ct200u ex I drove it for a little bit the when I tried to start it up again it was stuck and it wouldn't move
What do I do
We had the same problem had to pull the spark plug out and let the oil drain out of the piston area by pulling The pull string then it started right up
I have a Coleman ct200u and when I pull it starts easy I one time and after I turn it off and try to start it it wrist breaking how hard it is to pull I did take out the plug and pull but it keep doing it and I just bout it
And it started after I put a makuni carb and exhaust
If it's a old engine, the recoil wheel could have worn just 1mm and it would cause the whole housing to high center on the pivot. This would definitely make it difficult to pull once mounted.
Random _User_101 crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 33
crwdns2936753:07crwdne2936753:0 202
crwdns2936753:030crwdne2936753:0 809
crwdns2942667:0crwdne2942667:0 67,167
