The Samsung Galaxy Grand Neo was released in February 2014. It is a mid-range smartphone with a 5.01-inch display and a variant with dual SIM. The GT-I9060I model is known as the Samsung Galaxy Grand Neo Plus.
update installs up 96% and it just writes error
i have a galaxy grand neo plus. i tried installing a system update, the update installs up 96% and it just writes error and reboots and jams at the same stage of installation. what should i do. im stranded
Hi @ndothi
You should try following solutions:
  • Remove SD Card - if it’s installed - press volume down and power button for over 10second - your device will be restarted - Then you can try install update again
If the problem still ocures:
  • Restart your device to the recover mode and wipe cache partition of device - Then try update again
If still ocures:
  • Turn back your device using Factory reset
You can also try to install update in safe mode.
Regards
Ndothi Sikota crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 124
