Released in 2015 the Dell Inspiron 15-7000-7548 can be identified by the factory labels on the back of the device. Example: Released June 2009, identified by model number A1303.
How to repair keyboard keys?
Hello. Im facing difficulty while using few keys on in laptop keyboard. Few keys like X, 3,7 need to be pressed hard to 2-3 times to work. Other keys are working fine. What could be the issue? How can I repair this issue? Thank you.
crwdns2944067:04crwdne2944067:0
Did you spill soda on the keyboard? It sounds like you need to wipe out the gunk that was left behind. It's an easy enough fix, you will need to make sure the device isn't plugged in and then drain the remaining voltage buy holding down the power button.
No nothing happened of soda spill incident. I once opened my laptop to change hdd. It's happening since then.
Thank you so much.
I got my keyboard replaced by Authorized Dell Executive. Its been working smooth since then. Thank you for your help.
Hi @ethanhunt ,
The best way (but not the quickest) is to replace the keyboard.
You can cause more problems than what you had when trying to repair keyboards.
They are not that expensive to replace.
Just search online for Dell Inspiron 15-7548 keyboard to get results for suppliers.
Here’s a link to the service manual for the laptop, taken from this webpage.
Scroll to p.57 to view the necessary pre-requisite steps and then the procedure to remove/replace the keyboard.
Ethan Hunt crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 858
