Rechargeable indoor/outdoor Bluetooth speaker. Capable of using USB, AUX and SD card for music input. Product released in 2014.
Speaker does not turn on!
I have had my speaker for a while now and for some reason everytime i try to turn it on but it doesn’t actually turn on. I already tried charging it for an hour and it didn’t work, any help??
Where would I buy the battery at?
Happened to me. It's a faulty power button. I need to replace it. But I found out that strategically position it in a specific spot, it will turn on. Like in the middle. Sometimes take like 10 seconds to get it working.
I am having the same problem, but mine is actually the switch. Can it be replaced? It will turn on sometimes if you move the switch to on and then back towards off just a little. Sometimes it work and other times it will not come on at all. Have had it about a year and half. But hardly ever use it. Probably doesn’t have 15 hours on it.
Try another charger to make sure that isn’t the issue. Otherwise check out this troubleshooting page for your device. If there isn’t any charging port damage you’re aware of, you may need to replace the battery.
Which is the batterie on my Axess SPB 1031????
Saira Mendoza crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,570
