The Capresso Infinity Model #565 is a conical burr grinder that is used to grind coffee beans varying across sixteen settings from Turkish fine to coarse.
Casing seal ring capresso 565
What is the correct way to reassemble the plastic ring that sits between the outside stainless steel casing and the flat plastic ring?
I can get it in the right slots but it won’t make a tight seal!
here are the pictures
@nicole_p take a look at these guides Capresso Infinity and see if you can identify the "plastic ring that sits between the outside stainless steel casing and the flat plastic ring?" If you cannot take some pictures and post those with your question. That way we can see what you see. Right now it is hard to know what exactly you are looking for. Adding images to an existing question
Nicole crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 130
