Released in 2014, the Lenovo C560 is an all-in-one computer with a 23-inch screen and optional touchscreen support.
Computer Wont Boot Up
I have a Lenovo c560 all in one and recently I had been running into some trouble regarding its booting. Sometimes it will boot, and sometimes it wouldn’t. Eventually it stopped booting completely and would just be a black screen with a feint clicking sound so I decided to do some research, and saw online that changing the hard drive cable would work so I tried this and it worked initially but then wouldn’t work again. Can someone please help as I need for work. Thank You
I dont know how to use the usb if the pc wont load. Is there a key I press on startup because nothing shows on the screen at all at any point
Press F2/10/12 ESC or DEL imediately after you turn on the pc. It's either of those which will get you in the BIOS or bootmenu.
If the computer won’t boot and there is a faint clicking sound, then your HDD hard drive may be failing. HDD hard drives make a clicking sound when they are about to permanently stop working. You may have to get a new hard drive soon.
If there is data on your hard drive that needs to be saved, please save it immediately. If you cannot salvage the data, perhaps a technician can do it for you.
Might be your HDD dying.
  • Try resetting the BIOS to default settings and see if that works.
  • Get a Windows 10 installation usb stick and run startup repair
  • Install Windows on a fresh HDD and see if it boots from it
Anthony Johnson crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,387
