Relay clicks, but dryer won't turn on
I’ve got a Kenmore model 110.78832700 natural gas dryer that’s stopped turning on. When you click the start button you can hear a relay click, but nothing happens. Before it stopped working you’d sometimes have to give the drum a push to get it to start spinning, so maybe I’ve burned out the motor?
If I’m lucky it sounds like my issue might be the thermal fuse:
https://www.repairclinic.com/PartDetail/...
Any ideas or things I should check? Or should I just start by replacing the thermal fuse and see if that fixes it?
Model info:
Update: I disassembled it and bypassed the thermal fuse (I think), but it’s still the same behavior. I also broke the belt, but it looks like it was ready to break. There was huge amounts of lint everywhere inside the dryer, which can’t be helping it. I’m not sure if the next culprit is the actual motor, or ?
Lint everywhere:
Guts:
Broken belt:
Motor:
Motor details:
Bypassed thermal fuse:
Update 2 (testing thermal fuse, start switch, and door switch per @mayer)
Thermal fuse seems good, I have continuity over the contacts:
Start switch seems good, no continuity normally, continuity when pressed:
Door switch I’m not entirely sure on, I have continuity between white and brown when not pressed, no continuity when pressed. I’m not certain if this is correct, but I do also hear an audible click when pressing/releasing the door switch:
Update 3:
I found a troubleshooting guide inside the dryer! I haven’t entirely comprehended everything in here, but it includes a wiring diagram and it seems like a lot of other good information. If anyone has ideas on what to try next I’m all ears…
Dryer Troubleshooting
Update 4:
I ordered a belt:
https://smile.amazon.com/gp/product/B00M...
and a motor:
https://smile.amazon.com/gp/product/B00D...
I’ll report back after they’re installed…
Update 5:
I plugged in the new motor and it turns on! I also received the new belt and it looks to be correct. However, I’ve been unable to get the blower wheel off the old motor (and at this point I think destroyed that blower wheel):
Also, I think I’ve found the root cause of this whole problem, the idler pulley barely turns and looks like it has belt burned onto it:
I’m still in the process of figuring out how to get the blower wheel off the old motor…
Meanwhile, I’ve ordered a new blower wheel:
https://smile.amazon.com/gp/product/B008...
And idler pulley:
https://smile.amazon.com/gp/product/B00H...
Once the wheel and pulley arrive I just might be able to put this all back together and have a dryer again!
Update 6:
I received the blower wheel and idler pulley. The wheel’s correct, but the idler pulley is the wrong part. It’s more-or-less a mirror image of the part I need.
Old is on the bottom and new is on the top:
I definately ordered the wrong part. Trying again, with what’s hopefully the correct idler pulley:
https://smile.amazon.com/gp/product/B018...
Update 7:
It might be fixed! I think I’ve got a little bit of alignment problem between the blower wheel and the lint screen duct. If I put the screws in all the way the blower wheel rubs, but as long as I don’t tighten down the screws it’s fine. I’ve also got a few extra screws…
Look at my dryer turning and burning and blowing!
crwdns2944067:04crwdne2944067:0
Nice job I’m having same problem and the effort u made here is going to help A LOT thank you
Im having an issue the check lint screen light wont stop flashing and dryer wont run, ive cleaned all lint out, and replaced the motherboard per sears but still having the same issue, any ideas?
On mine, I had the same symptom, a relay clicks when you push Start, but the dryer did not turn on.
The problem was a broken belt. The thermal fuse, and door switch tested good.
Whew that was so helpful of you to put all the steps and updates you went through. I wish so much that everyone would do that. I watch so many videos about the electrical problems on my Colorado and so do others. I would say MAYBE 10% of people take the time to show you how they fixed their issues. The rest of us 90% are in the same boat as we were before we posted for help! Thank you so very much for the information.
Kathy
Success!
I’ve learned a lot about how my dryer operates, and it’s once again happily spinning and drying clothes.
I think the root cause was a bad bearing on the idler pulley. The idler pulley keeps tension on the belt, and the stuck pulley then put too much strain on the motor and burned it out. The belt broke during disassembly, but needed to be replaced anyway. I broke the blower wheel during disassembly, so that was the only “unnecessary” part of this repair. The dryer was also desperately in need of having the lint cleaned out from all its parts.
Idler pulley: https://smile.amazon.com/gp/product/B018... $7.15
Belt: https://smile.amazon.com/gp/product/B00M... $12.98
Motor: https://smile.amazon.com/gp/product/B00D... $54.44 (was refurbished)
Blower Wheel: https://smile.amazon.com/gp/product/B008... $30.98
My grand total: $105.55
Had I maintained my dryer and cleaned the lint out and replaced the idler pulley and belt at the first sign of the drum not spinning easily, this repair would have been vastly easier and required only $20 in parts. Thanks @mayer for all your suggestions on this!
J
Just wanted to add some helpful info about this situation. There is a broken belt switch on most dryer motors. If your belt breaks or comes off, the idler pulley assembly is pulled down by the spring attached to it. When the idler arm goes down it contacts the broken belt switch, and kills power to the motor. If your trying to test a motor and the belt is off make sure you remove the idler assembly or lift it off the switch. It can be hard to see because they are mounted on the bottom of the dryer, usually right next to the motor. If your belt is off you should be able to look under the idler arm and find it. If you google broken belt switch there are several videos and pics about them. I dont know if the dryer in this forum had one or not, but most driers that have an idler with a spring attached to it do.
And the nut that holds the blower wheel is almost always left handed threaded. May have been why you had trouble getting it off.
Thanks for the article. So much work. I don’t have the patience or aptitude for this. I think I am just gonna buy a dryer.
Use a multimeter to test the fuses before just replacing things willy nilly.
Digital Multimeter
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Cause 2
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Switch
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the “click.” If the door switch makes a clicking sound, it is probably not defective. If you don’t hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
BELT unable to find this part
crwdns2886500:0Versatile multimeter with all the right functions for basic electronics troubleshooting.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Digital Multimeter
$59.95
crwdns2889612:0crwdne2889612:0 7
Thanks for the helpful tips @mayer!
I edited my question with updates so I could post more pictures.
I wish someone I knew got what you said about fuse replacement :-(. They bought a bag and think they can get away with it.
I've even told them to check for another fault if it happens to a 2nd fuse.
Replaced thermal fuse. Waiting for thermistor to get delivered. Hoping this fixes my issue. I have a multi meter but haven't a clue how to read it
Im having an issue with the check lint screen light on my kenmore 700 series electric dryer, ive cleaned out all the lint, and replaced the motherboard, but still having same issue the dryer wont start, everything else lights up and comes on but the lint screen flashing light and is causing the dryer to not work any helpful ideas? thanks in advance!
What if the drum want turn
Luke Soules crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 113
crwdns2936753:030crwdne2936753:0 401
crwdns2942667:0crwdne2942667:0 52,645
