The HP 15 laptop can be identified by the model number R263DX.
How can rid of a black spot on my pc?
Yesterday, i got a little black spot on my pc screen. I don't know why.
And this morning i found out that is getting bigger.
Is there any solution to fix it without the need to replace it.
Occasionally, the pixels on your computer screen will get stuck and you may see a red, blue, green, white or black spot. If you have a LCD computer screen, try to remove the broken pixel by lightly rubbing on it. Otherwise, use a software application to help you to remove it. Software such as Jscreen Fix, Pixel Fixer and Dead Pixel Buddy are designed to locate and fix broken pixels on a your computer screen.
Actually, i tried Jscreen Fix for about an hour. And nothing special.
Hi @dhia1 ,
Just to eliminate the remote possibility that it is not a screen problem, try connecting the laptop to an external monitor and check if its' display is OK
@jayeff Ok i will try it later.
Dhia eddine crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,208
