The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
Waterlogged controller ( need help)
So my little brother was playing with my controller and he spilt a little bit of the water on the black pad (rectangle) and a drop went into the charging bit, any help, this happened only 1 day ago
Hi,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the controller’s operating design and could damage the components.
First do not turn on your controller and then you need to remove the battery as soon as possible from the controller to minimize anyfurther damage.
Then you need to dis-assemble the rest of the controller and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the controller might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your controller.
If this process seems too daunting, take your controller to a reputable, professional electronics repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Shelly Shell101 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 183
