The Kenmore Model Number 970-678431 is an inductive cook-top range with single door oven and warming-drawer.
Dimmed Frigidaire stove electronic display
( right model Frigidaire BFEF374A )
I bought this used stove and the digits on the digital display are barely visible. I sought a solution and found that cleaning contacts or changing the capacitors might solve the issue. Contacts of the display are welded in the unit’s board but I changed the capacitors and it is still the same.
Possibly a cold solder joint on the control board. Reflow it it with a cheap soldering iron.
That failing, replace it.
Thanks Mayer, I will revisit this option. I admit I did not check if all the solder joints were still intact.
Bob Harris crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 385
