Black and Decker TO3250XSB Convection Oven Repair, removing clips
How do you get the clips off of this device to completely remove the cover? I’ve followed all steps and removed all the necessary screws but cannot reach the clips to fully remove the cover. Any suggestions?
I’m not familiar with this particular model but all of the similar appliances I have worked on usually have a cover that wraps around on three sides. After removing all of the cover screws, slide the cover towards the rear of the oven for about half an inch. The cover should then lift away from the main body. Hope this works for you.
Thank you for your reply but this model has side clips that need to be squeezed and slide though a slot in the cover to take it off. The problem is that the clips are on the front of the unit and welded to the face of the unit. I can't get my hand deep enough into the unit to squeeze the clip and slide it through the slot. I was hoping for a trick that would work.
Please post a couple of photos. Here's how Adding images to an existing question
Lari crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 907
