Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Help! Split liquid on trackpad MacBook 12” what to replace?
I had Spilt coffee on my MacBook Pro 12” notebook my trackpad is not working would what would I need to replace to repair it!? Thank you for you’re time much appreciated!
Update (02/16/2019)
My MacBook 12” is completely functional except the trackpad. Would I only have to replace the track pad and the trackpad flex ribbon cable?
You can also buy the ribbon cable here: MacBook 12" Retina (Early 2016-2017) IPD Flex Cable
I would inspect the connectors for liquid damage first however. I also don't think you would need to replace the cable necessarily. If you can't clean out the damage, just a replacement trackpad with your original cable will probably work fine. I would try that before buying a replacement cable as well. Especially if your keyboard still works.
Okay thank you! Can I get a link for the right replacement tools I would need to take apart the MacBook?
You can buy a replacement trackpad for your laptop and follow this guide to replace it.
Look through iFixit’s Electronics Water Damage guide and make sure there isn’t any corrosion or other damage internally. If you notice minor corrosion or liquid damage to the trackpad you could try fixing it with the techniques outlined on that page as well, before buying a replacement.
crwdns2886500:0Replace the "Force Touch" trackpad for a 2016 or 2017 MacBook 12" Retina model A1534.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
MacBook 12" Retina (Early 2016-2017) Trackpad
$69.99
Shay Whitford crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 100
