The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
How to replace WIFI antena? Paste it? what about cables?
Hi,
In this picture its the iPhone 2g without the LCD:
http://img217.imageshack.us/img217/1135/...
Which of the white cable(1, 2 or 3 in the pic) is responsible for the WIFI signal?
How can I know if the problem is the cable, or the whole ANTENNA Module (the red square in picture)?
the phone/network carrier signal is OK, its just the WIFI which bad.
And if I buy this Antenna module:
http://img861.imageshack.us/img861/817/4...
How the I replace it?
I should paste it?
Is it difficult to install it?
thanks
crwdns2889612:0crwdne2889612:0 -1
The white cable is an assembly of 2 cables with total 4 connectors - you need to replace as an assembly if you think it is faulty
See HERE and zoom the picture
This GUIDE should assist in replacing the Antenna module - specifically from step 21.
The module is likely held in with double sided tape. Something like THIS may be suitable for re installation.
Wow.. Thanks for nice answer:)
I have a friend that his WIFI doesn't work.
So I thought to open his iPhone, and try 3 things. Please tell me what you think:#see if the white antenna cable connected in their places. #replacing the Antenna module with Antenna module from an old iPhone. #buying a new Antenna module or white Antenna cables if nothing will work.
Another questions:=*Where is the Antenna that makes the calling signal? I mean the 3G and not the WIFI? I want to know the risk of "playing" with Antenna module part.. if I can make more damage that it was before?
Thanks
By the way - i found out, that the wifi cable is only one of the cables that attached to the Antenna module, what makes me think that it is a big risky to replace the ANTENNA module because I can loos the ability to make calls - 2g/3g/gprs signal. here u see where the wifi is in the buttom,:
http://img191.imageshack.us/img191/5317/...
Shai if I remember correctly the cables are pop on/ off no glue required. Like iPhone 3G connector for wifi or 3GS connector 7.... So be careful and you'll be fine. The glue is a low temp silica type that they put on at manufacture/assembly to keep everything in place. You don't really need to replace it
Shai crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 3,617
