The Vtech Kidizoom Smart Watch DX is a children's smart watch released by Vtech in mid-2017. The watch is designed for ages 4-12 years old, and comes in six different colors, all with the same repair guides.
How do I remove the touch screen from the watch?
I have the back removed off the watch . If I pop out the circuit board am I able to remove the screen and clean it off and remove the moisture that is stuck in there ?
Hello, yes it is possible. We had moisture between the display and front screen and could remove it. I just gently removed the white plate at the bottom with a small and thin screwdriver.
Be careful not to bend the display component (the white part). The glue holding it in place is flexible and reusable, but fairly strong. While removing the display from the cover, I noticed the display was starting to bend. I got more careful once I noticed, but when I put it back together, the display only showed me a white glow with a black crackle across the middle. I recommend very gently breaking the grip all the way around the edge of the display before trying to pull the display from the cover.
Loreli Evans crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,424
