Shark Navigator Freestyle cordless stick vacuum offers portability and easy maneuverability. The vacuum can be identified by its model number SV1106 and sleek figure.
Random long spring pooped out
I took The bottom off and a spring pooped out and I’m not sure where it goes?
Could you post a picture of the part you were disassembling? It might help to see where a spring could've potentially gone.
Same happened to me. Vacuum still turns on when I have the bottom disassembled (white top unscrewed from gray bottom) and I push the on/off switch there. Ever since I disassembled and a spring popped out the on/off button will not start the vacuum. Any tips? Where do I put the spring back for a vacuum to turn on using on/off button?
There’s a grey tube by the power switch! You’ll have to reassemble the vacuum with that part at the bottom so it doesn’t fall back out.
froggy781 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 239
