The Mercedes-Benz 204 series is part of the mid-range C-Class model. It was produced from March 2007 to June 2015 and replaced the 203 series, which had been built since March 2000. Production of the sedan ended at the beginning of May 2014. Since the beginning of February 2014, the Mercedes-Benz 205 series has been produced as its successor. Production of the Estate model was discontinued in March 2014. The Coupé was the last model in this series to be built until June 2015.
Repair mercedes sam module at pc shop?
Actually i have an 07 mb e350, w211 body type, wasn't listed in drop down box. Trunk got wet and fried sam module/ signal acquisition module. This controls all car functions and are 3 of these which are connected to a fuse box on each. Can a pc repair shop do this repair. If the original from the car is repaired there is no need for any programming from a mb shop with the star diagnostic system. There are shops that do this but none near me. Also i believe at least 2 of the 3 of the sam modules have been affected. The other not by water but an improper battery change. Excessive arcing when connecting or disconnecting battery is apparently another main cause. My systems are all showing the tell tale signs, dash buttons and radio not working, system malfunctions on multiple systems etc. So would it be ok to ask a pc repair shop to perform this. I read a 64 pin, chip is the root of all this and bad design. Its just a computer board. Not a pc but i assume all the same components go into most circuit boards. Thank you. New sam units are expensive and still need programming, used would work if from exact same model but still need programming. Also most come from totalled vehicles which could have the same problem. Thanks, John.
Hi there!
If the PC repair shop has some normal people woking there they should be more than pleased to help you out with the SAM module. Not saying that they will fix it 100% but they at least can tell if the module is repairable. But if some water got in there that should just be a matter of soldering, cleaning and testing. I work in a PC repair shop and we do those kinds of things as well. Mainly because I have a car electric diploma :D!
Hope this helps!
What is the work of back Sam Mercedes Benz
@aluma Hey! Sorry for the very very late answer XD! SAM module controls all the rear electrical assembly... that is lights, door locks, sensors ext.
Hope this helps :)
John Bradley crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 4,275
