Screw on the bottom of the case spins in place.
So I bought some new better quality thermal paste and was planning to clean the old stuff off and replace it (heard a rumour that better quality paste would help increase the consoles life span and battery life in terms of holding a charge as high heat can reduce this) I had also removed the back metal plate previously and saw a post somewhere that said I should have applied it then so as to remove the risk of bubbles forming in the paste.
Anyway I go to remove the last screw and it just spins. The thread on the head is fine. It's to far in to wedge something behind it and I doubt a magnet will work. In need of ideas.
crwdns2944067:04crwdne2944067:0
Is the screw in a hole or can you access the entire screw head?
crwdns2934271:0crwdnd2934271:0 Alec crwdne2934271:0
It's flush in the hole
[image|1655812]
As if it's screwed it but it turns both ways and just spins when turned.
crwdns2934271:0crwdnd2934271:0 Chris crwdne2934271:0
I can't see your image but when something like that happens at my shop, i try to drill it out with a small bit, It will completely destroy the screw, but it gets it out.
Yea the button doesn't seem to work to put a picture up.
How far do you drill? Is the bit the same width of the screw? I'll be looking up tutorials on YouTube as I've never done this.
