The ASUS X44H-BRR4 is a laptop that was released in 2012 and has an intel core i3 processor.
turns on then goes off
i start my laptop up and as soon as it goes to the windows startup it shuts off.
Based off of the description you’ve given me, here are some quick solutions you can try. (Keep the charger plugged in for all of these unless specified otherwise.
  1. Power Cycle
    • Unplug the battery and the charger. Hold the power button for 30 seconds. Plug the battery and charger back in, and see if it boots. If not, move on.
  2. Windows Corruption
    • Windows constantly gets corrupted, try a fresh install and see if it still crashes. If so, move on.
  3. HDD Failure
    • You hard drive could be dying, try booting to a windows USB and seeing if it still powers off. If it doesn’t, replace the hard drive. If it does, move on.
  4. RAM Issue
    • Try using a different RAM stick and see if the problem still persists. If it does, move on.
  5. BIOS Reset
    • Start the computer and mash the “delete” key on your computer until the BIOS shows up. (If the computer shuts down while in BIOS, move onto the next step). Reset the BIOS to defaults by navigating through the BIOS to the save section and select the option similar to “Revert to default and save” If the problem persists, move on.
  6. Motherboard Issue
    • If the computer shuts down in BIOS as well, It’s likely an issue with the CPU or Motherboard, in which case you will want to replace the motherboard. This is the last thing I can think of based on your description.
alec do you work on phones or laptops at all or do you just copy and paste from google and the apple page
I work on laptops, Macs, desktop PCs, and some tablets. I'm just trying my best to help someone out. I'm sorry that I couldn't be of more help!
Rickey Hawkins crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 200
