The original Blackberry Bold smartphone, featuring various improvements from older Blackberry models.
bb thrown on wall doesnt boot
threw bb to wall cant boot no light nothing.
-keeping it plugged and putting battery in, removing waiting30secs and repeating procedure leads nowhere.
-keep escape pressed for safemode boot doesnt work
-keep mute button pressed 30secs doesnt work
mystery selfhealings
-keep 10 hours offline and repeat above doesnt work
next appreaoch keep 24hours ofline and repeat above
-no recognition of usb in computer link
-wahts broken ?
Check your battery, make sure you have any kind of output. Make sure that your battery makes a connection with the proper contact of your phone. After that it is time to perform a teardown on your phone and see what is obvious broken/disconnected etc. But do start with the power to your device. Good Luck and let us know.
nice idea but the usb doesnt recognise it. that does work usualy without battery, doesnt it>?
i suspect boot rom
THe battery is ok. If you ever have troubles wiht yours keep mute pressed 30-40 seconds
first plug in leave it plugged
pull batter wait 30 seconds
put in batter wait 10-20 seconds
keep mute top pressed for 30-40 seconds while on cahrger.
it should live again
turn device soft off while loading full
The reason why I always check the battery and contacts first is to make sure there is no shortcircuit to prevent the device from not being recognized when plugged in.
i see. The battery is ok. I exchanged batteries. So any idea waht could be broken > as i said the thing doesnt LED red, doesnt start no recognition as if the boot rom is damamged.
-is there a self healing possibility? leave it a day unplugged and it restarts? -read this a few times now
test crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,053
