The XV40 Camry was introduced at the 2006 North American International Auto Show alongside a hybrid version and went on sale in March 2006 for the 2007 model year.
p2763 code toyota blade
i AM ASKING UNDER THIS AS SON HAS TOYOTA BLADE 2007, CVT TRANS 2.4LITRE
BELIEVE ENGINE IS WHAT IS USED IN CAMRY. japanese import
ENGINE LIGHT AND VSC LIGHT COME ON DIAGNOSTIC CODE IS P2763 TORQUE converter clutch pressure control soenoid control circuit high.
do you think this is a solenoid only or clutch converter or transmission,
How many miles is on this car ? Has the transmission fluid ever been changed ? The most comon cause for this code are plugged filter . before tearing the car apart start with a complete transmission oil and filter changer then clear your codes and drive the car and see if this corrects the problem . If it brings no joy then you will need to replace the valve and solenoid . Hope this helps
Hi ! My vehicle has a 2011 RAV4 CVT transmission. I'm getting error code p2764. RPM fluctuates at certain speeds on the road. I'm wondering if I can follow these steps. Thank you.
SANDRA crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,894
