Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Fuel pump fuse has no power
Truck was running a few weeks ago then went to start no fuel so checked the fuse under the hood on the passenger side there is no power to it but there is power going to the one side of relay and changed that and made no change what can I do
If theres no power at the fuse then you need to trace the circuit back to the break in the wire . This is usually done by flipping the whole panel over and testing with your test light. If one connection is corroded enough to break it not long till others follow Hope this helps
So did you have a broken wire or just corrosion??
Dave crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,972
