Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
crwdns2944067:04crwdne2944067:0
Circuit board is burnt out. My machine just did this. Repairman came. Waiting on parts now. My washer is only 5 months old
crwdns2934271:0crwdnd2934271:0 wasilmon3 crwdne2934271:0
This should be under warranty
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
Where is the circuit board located??
crwdns2934271:0crwdnd2934271:0 Andrew Fradette crwdne2934271:0
Will it go through all other cycles if the door switch is faulty?
