What does error 234 mean
Hi,
Could you please advise what error 234 means on my touch screen, Fisher and Paykel washing machine means? If so how do I fix it?
Thank you so much!
Hi,
Thank you so much!
Error 234 means a Lid lock is defective
Unplug the washer and reconnect any loose wires on the lid lock assembly. Replace the wire harness if damaged. Measure the resistance of the lid lock using a volt/ohm meter. If the resistance isn't 63 ohms, replace the lid lock assembly. If the resistance is correct, replace the motor control module.
This advice looks as if it might be helpful in my situation. I have measured 66.2 ohms resistance in this mechanism on my machine. Do you mean that the resistance should be exactly 63 ohms?
In the lid lock there is a small plug connecting the solenoid to the wiring harness
This does corrode
Either replace the lid lock complete lr remove the plug and solder the wires together
crwdns2942667:0crwdne2942667:0 755
