The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
My cd player not working properly
HI I have a bose model AWRCC1 I am having problems with my cd player. I have used a lens cleaner with brushes to clean it It will work for a cd and as soon as I put in another cd it will start to skip again. Can you give me some advice please or recommend someone to repair it . I live in Niagara Region Ontario Canada thanks Benny
crwdns2889612:0crwdne2889612:0 7
I have a Bose Wave which cd player does not work. When I put it, reads but shows the message “Not Playable”. I have tried everything: clean the lens, unplug for cord, reset, tried to plug away from electronic devices. Literally EVERYTHING!!! Radio is good, no problem. Interesting used to work very well. Someday started not reading the CDS. I have brand new ones and does not wok.
What else I can do before smash this sound, which I love… ;-(
How to increase brightness on visual display?
The brush may remove any dust on the lens, but there is often a film as well. Use a cotton swab with some alcohol and gently clean the lens. Do not apply too much pressure as the lens is held in place with very fine wires. If the brush helps to allow a CD to play, the cleaning should be a bit more effective.
Report back with the results of the cleaning.
Dan
Cleaning the lens w/ rubbing alcohol on a soft cloth fixed the problem! The CD player works perfectly. Thank you, thank you, thank you.
I have the simular problem and it still does not play any CD's
mbdalessio crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 7,862
