Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Replaced IC chips and Now have this issue.
Hey Team,
I got the touch Ic chips replaced on my iphone 6plus, the camera and the wireless stopped working because the first repair shop apparently melted the board and ruined the connection
Then the phone would randomly flicker and come back and then flicker again to a point where i would need to firmly press on the top right of the screen and let go for the screen to come back from the dead.
I got the screen replaced aswell to see if that would fix the problem, but the problem came back after a few hours or when the phone would heat up it would start to lose its legs.
Then the phone start to randomly flash the apple logo when it felt like it, but it would come back when it wanted. So i could still use the phone but not at times i wanted to.
I got the battery replaced to see if that was the cause of the problem, but knowing my luck it was not.
Now the phone is in full Restore mode, no program can get it out, switching it on and off/ Hard reset, nothing has worked.
Its stuck on the apple Cable >> Itunes Screen. Is there a solution for this problem? Can i fix another part on the phone or is this it?
The guy at the phone shop actually said i dont know how this phones working but it is. I mean all the other parts on the phone are brand new, its the mainboard that has seen damage from phone shops stating they can fix the problem without using micro soldering and trying to cheat me.
Thank you for your time
iPhone honestly it's annoying because the user only gets to use it once not even that it's gonna last for long very short period of time and it's bad with so many issues
Unfortunately, it sounds like too much heat was applied to this logic board. When replacing the Touch IC, excess heat can cause some tiny components on the flip side of the board (where the Screen connectors are) to flow in the solder but because they are covered in epoxy, they tend to get sucked upwards and can have flaky connections.
The WiFi IC is right next to the Touch IC and it is underfilled. The excess heat can cause the solder balls to expand but are constrained by the under-fill - which can cause them to bridge (short) or blow out.
The first thing you should have done is gone back to the repair shop and have them try to sort it out rather that you buying all of these replacement parts. Whether or not the board is repairable is open for debate. Some of the issues sound easily fixable (camera, flicker) and some are more difficult (WiFi).
Update (12/10/2018)
Thank you for your prompt reply. So with the phone sitting in the Itunes cable icon mode (dfu), there is no targeted fix to solve this issue? is there something you can suggest me telling the phone shop to check? Any help would be much appreciated. Thank you
If you have a hardware issue on the logic board, there is not much you can do from a DIY perspective unless you know how to read a schematic and do some board-level troubleshooting.
Please i just fixed my Ic why is it till not charging
Same as above you need to find a competent repair service that does SMC repairs replacement and diagnosis on iPhone boards.
newrye crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 690
