The Dremel 4000 is a variable speed rotary device. It is compatible with with all Dremel rotary accessories.
Loose Wire Need Connection Point
My husband used my dremel to cut drywall. I’m sorry, ex-husband…. I took the tool apart and cleaned out as much as I felt was safe to do, but there is a wire loose that I can’t find the connection for. It’s a blue wire coming from the small board behind the speed adjustment. There is a brass “U” shaped hook on the end. Where does it hook to?
It attaches to the motor as well. The square shaped metal on the tip of the blue wire goes on a slot on one of of the sides of the motor brushes, on the plastic case. You may need to work it around to make it fit the slot. Then put the brush on the top of it.
Source: http://messageboard.dremel.com/Topic8053...
A Moryer crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 43
crwdns2959996:0crwdne2959996:0 669
