Why is my power board burning?
I’ve had my Vizio model M471i-a2 for about 4 years, and about a week ago it started emitting a strong burning smell, and then the top of the screen started having Black flickerings. Took off the back and saw a substantial burn mark on the power board.
Ordered a new board and put the new one in Saturday. Now (Monday night) the same thing is happening all over again to the brand new board!
Update (11/27/2018)
Here’s a picture of the other side
Update (11/28/2018)
Thank you turkey! Here’s a pic of the whole side of that board in case that’s helpful:
crwdns2944067:05crwdne2944067:0
Did you try connecting power through a different outlet?
Yes I did try another outlet
I have the same problem, did anyone find a solution for this?
Hey dude, it did end up being my LED backlights. I wish I would have known that before purchasing new boards, as it will just burn through any new board you install.
I have this same issue on the same model tv. Same burn marks on same board. Do I need to replace the backlights and the board or just the backlights?
@tardisgrooves
that is the cold side of the board and we really would need the underside of it as well. We would need to figure out what circuit those jumpers belong to. From their location I would think that this might be an issue related to the LED backlights. You can always try another board but do not connect the backlight connector and see if it does the same thing. without a schematic it could be difficult to check it any other way.
New pic below
@tardisgrooves those look like MOSFETS Most likely for the LED boost circuit. I will try and see if I can find a schematic to verify this.
Thank you turkey! Bigger pic below
I have the same problem If replaced the unit and it does again then what is the problem ?
Jonathan - LED backlights
Carey crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 800
