service light comes on and displays error code F08
error code F08 indicates a heater fault so I have replaced the element but still displays error code.
hello Simon this is the error code check the listed items from this error code.
The main control unit in the washing machine has detected that there is an open circuit somewhere in the heating circuit.
The main control unit will detect this error at the start of a program and during the spin phase.
In order to remove the error code: 2 options:
1 Reprogram the CCU which is known as an ETNA CCU (module). This will require a hardware key and an ESAM unit (neither of which are readily available to purchase).
2 Install a pre-programmed ETNA CCU for the correct model.
I’m adding this info in 2021 in order to help anyone who encounters the same problem.
BTW - I’m a field service engineer.
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 4,405
are you getting this on a washer or dryer. Please give us your model number.
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
hello Simon, this is the error code and listed are items to check with that error code..
Whirlpool washing machine water heating element open circuit error F08
F08
Open circuit error detected on heating circuit
Check wash heating element for continuity
Check the wash heater for earth leakage
Check wiring to the heater
Check the control unit
crwdns2934271:0crwdnd2934271:0 twofast2trackpro crwdne2934271:0
I have the same problem. After replacing the heating element, the code is still there. How to delete (remove) the f:08 code? Any ideas? The dashboard how to reset it?
crwdns2934271:0crwdnd2934271:0 Uran Malaj crwdne2934271:0
