SD card Is Unusable
My Kodak camera wont let me use sd cards (Iv Tested it on 4 other sd cards and it didn’t work)
Hi,
Have SD cards worked before in the camera?
What error message if any do you get when fully inserting the SD card?
Have you checked that the cards are formatted and can be read, by inserting them into a card reader connected to a computer?
Yes SD cards did work it hasn't ben able to read cards since 2015 and yes All the SD cards I tried worked on my pc
Your camera may be defective. A more difficult case, since its various components can fail: connectors, camera sensors, elements of the motherboard electronic media. In the latter case, the best way out will be to conduct diagnostics in a specialized center.
Welp I tried, Well I maybe just gona take it apart k
crwdns2947821:0crwdne2947821:0
Hi,
Check that the internal storage setting in the camera is set to Auto
Go to Menu > Setup > Internal Storage.
If it is set to “Internal memory” change it to Auto and see if the SD card is now detected.
If it was already set to Auto or if it still doesn’t work after you changed it to Auto, then there may be a problem with the card reader in the camera.
Unfortunately I haven’t been able to find a service manual or a video that may help in opening the camera so that the problem can be further diagnosed.
Hopefully you may have better luck.
OK,Well I better just throw it away.
Matt Pin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 5,443
