Repair and additional information for the Samsung RB195B*** refrigerator—an 2008 model featuring a bottom freezer, door access, and an anti-sweat heater switch. This page covers information for model numbers matching the pattern RB195B***.
Blinking interior light in Samsung Refrigerator
I have a Samsung RB195BSSB. The interior light in the refrigerator is intermittent. The light in the freezer has no issues. When you open the door, you can hear the relay click but the bulb barely flashes and once in a great while will come on, but typically never does. I’ve replaced the bulb but it didn’t fix it. What else? Door switch? PCB board? Any feedback much appreciated. It’s driving me nuts!
I have a similar problem
10 year old Hotpoint ff (HM315FF)
The internal light in the fridge (Edison bulb) flickers (6 times) and clicks sometimes (not always) when I open the door.
I have tried many fixes (changed bulb, phoned HP , switched off, adjusted temps) but nothing has been successful.
Having exactly the same issue with samsung refrigerator model rs267lbbp
The refrigerator light is not working proper
Hi @montanaman
Use a voltage detector -example only to check if there is power being applied to the lamp with the door open.
Unscrew the lamp and place the detector on the centre terminal of the socket (avoid touching the “threads” of the socket) and check if it lights up with the door open
Be safety aware when you do this, as it is a 120V AC lamp, lethal voltages are present when you are testing
If there is voltage present it may mean that there is not enough tension being placed on the base of the ES (Edison screw) lamp for a good connection when the lamp is screwed in.
With the power totally removed from the refrigerator, see if you can gently prise the connector terminal upwards so that the lamp will push it back down and make a good connection when it is screwed in.
If there is no voltage present on the lamp terminal it may be the door switch that is the problem.
There is only one door switch part #31 mentioned in the parts list, but when viewing the video on how to replace the switch, it is stated that it is a two button switch that operates the freezer lamp and also prevents the auger (presumably in the ice maker) from operating. There is no mention of the refrigerator light.
It is not a simple circuit to operate the lamp.
Here’s an image taken from the service manual. It shows that the door switch operates and sends a signalto the relevant section in the main control board which then operates the lamp. So basically door switch - main pcb - lamp. The problem could be anywhere in this path.
(click on image to enlarge for better viewing.
Fortunately the service manual does have a schematic circuit so that you can determine which connector the door switch connects to on the pcb and which connector the lamp connects to on the pcb so that helps a little bit.
Great advice. I will try your suggestions
Explain why the refrigerator is turned on for a while and then stop
@bathaw.ymz95 ,
Not sure what you're asking.
Please provide more details?
Is this happening when the doors are open or when the doors are shut?
What is the problem with your refrigerator and what is the make and model number if not a Samsung RB195BSSB?
When you open the door of theRefrigerator the light comes on once and then goes out straight away it’s a digital strip light ?
Steve R Hanson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 12,243
