Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Sleep sensor and magnet question
Hi everyone,
I recently got a good deal on a MAcbook 12 2016 model. All I had to do is to change the screen, as the seller managed to break it.
So I ordered a replacement screen, but unfortunately in the end it turned out to be a 2015 model, which only has a magnet on the left side, as the 2015 MacBook only has 1 sensor installed.
Because I didn’t want to go though the whole ordeal of sending it back, getting a refund and re-ordering I decided to make it work myself.
What I did was, I placed a small (not so strong) magnetic tape underneath the sensor on the bottom plate and the machine goes into sleep as intended when closing the lid.
However my question is, will I damage the sensor as it always senses the magnet or I will be fine?
It’ll be fine, the sensors are designed to be used with magnets.
Is this easy to do? What tape did you use?
Thanks in advance!
Update (06/09/23)
The only way I could fix this :)
Update (06/08/23)
Like this :)
Update (06/08/23)
If you don't mind me asking: is this the sensor?
crwdns2944067:010crwdne2944067:0:
Was quite easy. Just had to locate the sensor. What I did after is that I just used a magnet tape and placed it underneath it on the bottom cover :)
Thanks for your reply!
So I am testing this, as a total noob, with a little magnetic strip on top of the case. The macbook goes into sleep, but on reopening the lid it won't wake until i remove the magnet piece. Does that make sense? Thanks
See image in next comment
That might be too big, but it goes inside though :)
Yeah, but the problem is when i reopen the lid it doesn't wake in this test situation, i have to remove the piece to wake the laptop :(
Cheers
So I guess in my case it is not working with testing it like I did, but I will test it with smaller magnetic tape inside the case. Thanks
crwdns2934275:05crwdne2934275:0
Gergely Sik crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 508
