A corded phone with companion cordless phone developed by Uniden.
Stop switching to message bank while we answer the call
I would like to stop switching second call to message bank while we answer the first call
Update (11/17/2018)
I would like to show the line busy sounds when second person calls in
I would like to keep line busy for the second caller.
Update (11/17/2018)
This function answering the second call through message bank is uniden phone or from Telstra provider?
If change phone it would fix the problem?
Thanks
Hi,
You need to turn off the Call Waiting feature for the second call to get the busy signal when you are on a call.
If you don’t wish to do this then the only way to stop the second call going through to messagebank when you have been notified by the tone signal that you have another call waiting, is to answer it by pressing the Flash key on the base unit or the Talk/Flash key on the handset and then telling the caller that you are on a call and to either call back or to wait and then switch back to the 1st call by pressing the same button again. Be aware that there is a slight pause before you connect to either call after pressing the key.
You could always extend the ringtime before being answered by messagebank by dialling * 99 (Enter the number of seconds you wish the phone to ring before a call is diverted (between 5 and 60 seconds) # and hang up. e.g. for 60 seconds dial *9960#.
The above is for Telstra messagebank. If you use a different phone service provider, check their website on how to extend the ringtime for their voicemail service.
This time setting will affect all calls to the number, that haven’t already been answered by the phone’s answering system ringtime setting (6 rings maximum - approx 18 seconds).
If the phone’s answering system hasn’t been setup then the phone will ring for 60 seconds before being diverted to messagebank. The phone’s answering system doesn’t respond to CW calls as there is no ringing current being received by the phone.
You will then need to answer the second call within 60 seconds of being notified by the tone signal that you have another call waiting to be answered otherwise it will be answered by the messagebank service. The 2nd caller will be receiving the ringtone signal as with CW they do not know that you are already on a call.
Hi,
Changing the phone won't help.
Telstra controls how messagebank works, you can only control limited settings in messagebank.
As I said, if you want the 2nd call to get busy when you are already on a call on the phone then you have to have Call Waiting disabled.
You cannot do this while you are talking on the phone. It would have to be done when the phone is not in use.
To disable Call Waiting pick up the phone and dial #43# wait for the notification message and then hang up.
To enable Call Waiting pick up the phone and dial *43# wait for the notification message and then hang up.
That is the whole idea of Call Waiting. It is designed to let the called party know that there is another caller on the line, waiting to be answered, not to let the calling party know that the called line is in use or not.
Pairatch Paotrakul crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 202
