Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Blue stains on screen
Some blue stains on bottom of screen only on black color and on dark backgrounds like boot screen and others. On white backgrounds aren’t visible. Does not affect performance or tactile sensations.
It’s almost invisible, but it is
[image|1643329]
Without giving us any context or background (was this following a drop or repair attempt?), the screen could be improperly mounted or damaged. Give us more info and we may have better guidance to offer.
I didn’t drop it and also didn’t give it to repair.
This could be a sign of a bad LCD. Can you post a picture (add it to your question)?
It's pretty subtle...if the device wasn't opened up for repair and the housing isn't damaged or warped, then I would just suspect a bad LCD. Unfortunately, the only way to know for certain is to try a known-good replacement LCD.
To me it looks like a pressure mark. I know you said it hasn’t been dropped/repaired, but if it is at all bent or warped it can cause it to appear. Someone may have sat on it or something like that. Outside of that, the other comments are right it’s probably a bad LCD. Are you sure the mark is new, or are you just now noticing it?
jiraya crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,644
