Left headlight low beam inop
Where is the fuse or relay for the left low beam head light located on a 2005 Nissan altimal 3.5. No power at bulb
Hi @trobi ,
Here are two images taken from the service manual -lighting system LT for a 2005 Nissan Altima describing and showing the fuses and wiring details for the headlights.
(click on images to enlarge for better viewing)
IPDM E/R means Intelligent Power Distribution module Engine Room.
If fuse #45 appears to be OK you need to check that there is power available at terminal #30 of the IPDM E/R harness connector (remember to turn on the headlight switch - low beam ;-)
If there is power available there, then there is a problem with the harness to the light.
If there is no power available there according to the manual on p.LT-23 the IPDM E/R module needs to be replaced.
The fuse panel is next to the driver’s left knee. There should be legends for all fuses in that panel or on the lid.
crwdns2942667:0crwdne2942667:0 9,473
