AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
60W Magsafe Charger Making Ticking Noise, Not Charging
I have a 3rd party 60W Magsafe charger that suddenly stopped charging. I tore it down, and applied a voltage to it. I hear a ticking noise, but I’m not quite sure which component could be failing. I get no output voltage on the Magsafe pins (no surprise). Any assistance would be greatly appreciated, before I desolder the board and test each component individually. Tia!
To be honest, you are really better off getting a replacement charger than try to fix it because the quality of aftermarket ones aren't that great they burn out and cable gets worn too easily.
They are also not very good or safe! Why You Shouldn't use Cheap MacBook Chargers
gradidgek crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,069
