Slow charging in my Samsung s8 plus?
My phone keep saying that is charging slow, and I am using my original charger, and the phone is new.
If your phone is new and you are experiencing problems then the first thing you should do is contact the store. If that is unsuccessful then you need to contact Samsung for a repair under warranty or advice on how it can be fixed. I would not be trying any hardware fixes at this stage. It may be as simple as an app running in the background, back your phone up first and then contact the above.
The phone is like 3 months old, but the problem started like 1 month later. But thanks
Should be covered at least a year....
First of all, isn’t this phone quite new? I would check to see if you are under warranty by visiting this website here. If you do so determine you are not under warranty, it could be either a bad charge port or a failing battery.
Samsung Galaxy S8+ Battery Replacement
I changed the battery but still I’m having slow charging problem. It shows it’s charging fast but it doesn’t. When I plugged it at %20, it says 1 hours 10 minutes left. I go and when I went back after 1 hour I see it only charged ~%30 instead of ~%80
Bryant crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,698
