The ZTE Quest n817 is an Android smart phone that was introduced in 2015 and is commonly provided by Assurance Wireless.
Battery terminals are broken can the terminal block be replaced?
My ZTE N817 shorted at the battery when I plugged in the charger, I broke one of the 3 terminals that connect the phone to the battery, I tried to solder the broken terminal and the phone did start up when I put it back together but, the battery was to low to keep it on. I plugged in the charger but, it wont charge..Is the phone fixable?
If the battery is really drained you may find that it will not take a charge. You can try a trickle charge overnight connected to PC / wall outlet etc. In the past I have had success with charging the battery using a 9v battery, connecting it using a wire from each terminal of the battery to the corresponding phone battery terminals…it only takes about a minute until the battery charge is enough to then accept a charge via the wall socket.
Forrest Ballard crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 684
