The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Why is the htc not rebooting?
My phone was on 35%battery, put it to charge and it automatically switched off. Several attempts were made to get it powered up but no success.
I tried all the tricks with the toggle buttons, still nothing. The HTC android screen appears…then shuts downs again. The battery sign comes on showing 0% stays for a while then nothing. I tried several different charging cables no change in the phone.
The phone is only 18months old, however i have experienced a bootloop once before.
Any suggestions to fix would be greatly appreciated.
I think my phone's got the same issue. it started with some troubles charging and after a while it stopped charging. now its battery is out and it can't charge anymore, the red LED indicator doesn't turn on when I plug it in.
The question is whether it's a battery issue or it's the charging IC and which one needs to be replaced.
Try to access recovery mode so we can do a hard reset with the guide below.
https://www.hardreset.info/devices/htc/h...
I tried both soft and hard reset. Pressed buttons for two and more continuous and the phone never switched on
If the battery is low (under 70%) nothing works anymore. Only external USB power will help. The battery power can drop from 100% to 0% within two clicks, starting an app and the phone shuts down. To fix this: battery replacement…
Happy camper crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 247
