Freezer Compressor Start Relay Defective, How to Test
I believe my compressor start relay is not working but I want to make sure I tested properly before purchasing a new relay. On the side with voltage going to the relay, I tested the two leads with an ohmmeter and there is no reading (infinite) on the other side going to the compressor there are three leads. When I test I get a reading on two that equals around 10 ohms and putting the leads going to the third no reading. I think this side of the relay is good. My question about the reading going into the relay is because I am not sure if there are parts inside the relay that would alter a normal reading which I think should be around the same as the side going to the compressor. The part # for the relay is 297051004 if interested. Thanks for any help anyone can provide.
