Repair guides for the the LG V30, released in September of 2017.
crwdns2934591:020crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Can I reseal the back of my water proof phone?
I have an lg v30. And ive noticed the back is loose by the corners. Does this mean its not water proof anymore? And is there a way I can get it to reseal completely again to make it waterproof? What will I have to buy?
Can you reseal it for waterproof protection, no. Typically, once a device is damaged or opened you lose the waterproof with the manufacturer seal. You can purchase a new adhesive that was made for that device, if available, and reseal the device yourself. Just keep in mind that it may not be completely waterproof, but the seal will help prevent liquid from coming it.
Check the model of your device, I believe this should match your model. Adhesive seal
crwdns2942205:01crwdne2942205:0:
@juax Thank you providing a good answer!
I have an LG V30 and got a mobile protection plan, if you purchased one you could possibility send it in and get it replaced for a tenth of what it cost to buy a new one. That would be the best bet to guarantee a true water proof seal.
Yes and No:
Yes: In theory, if you add a brand new adhesive gasket to the frame on the inside, it should IN THEORY reseal the phone. You will need to remove the old adhesive gasket and make sure no residue is left by using isopropyl alcohol then apply the new gasket and I would say reheat the back pannel at around 110 C for maybe 1 min with a heat gun or heat plate then put the back on the phone this is to make it sticky and seal properly and put a few heavy books on it for a few hours but 24 hours is recommended this should recreate the seal.
No: Even from the start the manufacture does not guarantee any insurance from water damage and this is because your phone is never truly waterproof and the gasket seal will wear and tear over time after all it is a rubber type of double-sided sticky tape layer that keeps the back on the phone and prevents water from getting in.
But how important is the repair I need to change my LG v30+ battery as it doesn’t hold a charge anymore and needs a power bank 24/7, would you rather have a non-functional waterproof / water resistant phone or a fully functional non-waterproof / water-resistant phone. I know what id rather have and if the screen is cracked your phone’s water resistance is compromised anyway.
Adhesive Gasket Tape: https://www.ebay.co.uk/itm/184392178454
Ben Fryer crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,354
