2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Starts up and then shuts off after 3-5 seconds.
Sometimes it will boot into the apple logo and loading bar.
Will only power on with charger.
Have tried to disconnect the battery.. while using the charger. The same problem.
No water damage.
What could It be?
Logic board?
Battery?
Please help.
Disconnect the battery and mag-safe. Press and hold the power on button for 10 seconds. Reconnect the the battery and mag-safe. You should get a spontaneous reboot. It it does not boot all the way, tell us what it does do.
UPDATE 9/25/18
At this point try booting up holding down the option key and see if it will see the repair partition.
Next, I would try booting from an external source, both with the SSD blade in and out.
crwdns2944067:014crwdne2944067:0:
I will do that in 12 hours. Hope you could be available to answer shortly after that. thank you in advance.
@haakonem In 12 hours I will be asleep. I am CST time.
have now tried the things you told me.
1. Disconnected the battery and MagSafe charger
2. pressed the power button for 10 seconds.
3. Reconnected the battery and MagSafe.
4. Got a instant reboot.
5. The Apple logo and loading bar comes up. Goes halfway, and then restarts immidietaly.
6. Goes halfway again. When it comes to the halfway-line it looks like the screen becomes "slightly" brighter for 1 seconds before it immediately shuts off. But this time it shuts off. Not restart.
7. Tried to boot it up again, and the same thing. No hard-commands works, like Reset SMC, NVRAM, PRAM, etc.
8. No liquid damage or anything.
Please help.
@mayer Thoughts?
See update to answer
crwdns2934275:09crwdne2934275:0
you can try this in the interim: boot into your MacBook Pro’s Recovery mode by holding down a Command key and the R key as it starts up. When the Mac OS X Utilities menu appears, select Disk Utility. On the left-hand side of the Disk Utility window, select your internal disk’s boot partition (typically called “Macintosh HD”). On the right-hand side, press the Verify Disk button if it’s not greyed out; if it is greyed out, or if it reports that it found errors, press the Repair Disk button. Once the verification/repair is completed, exit Disk Utility and select Restart from the Apple menu to restart into normal mode. Do you still get the same grey screen + progress bar + beach ball of doom?
If it still not work than visit local authorized repair center.
Hi. it isn't any grey screen. and cmd + r won't work, because it just shuts off right before that.
@patriciajackson Welcome to iFixit ;-) please check your personal business link in your profile. getting 404 error
its working now mayer ! thanks anyway
Have you tried a SMC, NVRAM or PRAM reset? If so, try doing all of those types and see if it works out.
https://www.macworld.com/article/2881177...
Tried all that. Nothing worked.
@haakonem If that didn’t work, I am skunked. Maybe @mayer can provide some insight of what the problem could be.
I am facing the exact same issue on my 2018 macbook pro. Did you find the solution @haakonem ?
haakonem crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 183
crwdns2942667:0crwdne2942667:0 6,215
