How I can change a touch shot bottom
The touch bottom not work with the zoom and pictures eader?
Following the repair guide referenced below, you may find the problem is simply a ribbon cable connector which needs to be reseated.
If not, search on eBay for another camera of the same make and model but with a different fault. You should be able to get one quite cheaply. Then learn how to disassemble it using the guides here and any other guides or videos you can find on the Internet. You should then be able to swap out the shutter and lens controls between your camera and the one from eBay. From a quick look at the guides it seems you may need to swap the entire front cover of the camera with the shutter and zoom controls attached, but that’s not a problem.
Having fixed your camera you can then try a more radical disassembly of the dead shutter and zoom controls to see whether they are fixable - it won’t matter if you break them further in the process. You might even be able to fix the camera from eBay and sell it for a small profit!
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 119
I'm afraid your question is not very clear. Please could you describe in a little more detail exactly what doesn't work, and what still works. How did the fault appear? For example, did it do so suddenly appear or did it appear after a period of disuse?
If you don't find it easy to express yourself in English, that's not a problem. Try stating your problem in your own language and someone here can translate, or get a translation online.
crwdns2934271:0crwdnd2934271:0 Philip Le Riche crwdne2934271:0
The shutter button don't work to take a picture and zoon either, how I can fix?
thank you!
crwdns2934271:0crwdnd2934271:0 Francisco maldonado crwdne2934271:0
