Asus Q534U is part of ASUSTek Computer Inc. Q-series laptops. The laptop has a 360 degree folding hinge that allows the device to change between laptop and tablet by a simple fold.
Asus Q534U power button mashed into case body; needs replacing
Hello!  I have an Asus Q534U laptop, and it took a tumble from about 30” in the air, off a rolling suitcase, while in its laptop bag (padded on 3 sides, but not the top … ugh!).  Bag tumbled top over bottom, hit the floor with an audible thump, I started praying.  Turns out the unpadded top of the bag, where there also is a small niknak pocket, must have had some small item in between the laptop and the floor.  The laptop hit this random object directly across the power button, mashing in the silver button cover and slightly denting the case directly over side button.
I’ve “dug out” the button cover, and kinda unbent the case about the area (wasn't too bad), but the power button is entirely unresponsive.  I think it needs changing.
Is this something you can help me identify the part for?  Any thoughts if this is something I can manage to access fairly easily?   I can manage the tools and any basic soldering, but I'm really hoping its simple plug and play component.
Appreciate the help!!!  Repair shop/Geek Sq seemed entirely unreliable and looking to rip me off.  With your help, maybe I can save myself.
Update (09/18/2018)
Could you post some pictures of the damaged area and the button, so we get an idea of the situation.
the scratches seen in the last photo were made by me, leveraging the button out of the case where it had been jammed in and upwards. the scratches on the case are also me. the initial damage was rather innocent looking, till I noticed the power button missing (found inside the upper lip of the case hole). thank you again for asking to take a look
thank you!!!!!!!!!!!!!
Hi @richardsst ,
Here’s a link to the ifixit Asus Q534U guide.
It is helpful as it shows how to access the components in the laptop.
It may be that the power button in your laptop is actually mounted on a separate pcb module.
Once you’ve opened the laptop you’ll be able to verify this.
If it is on a separate board use the “board number” printed on the power button board in the search term of a browser to search online for a replacement part. I’ve searched for an Asus Q534U power button board part without success. You may have better luck if you know the part number.
RichardsST crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 535
